跳转到主内容
Samsung Captivate Camera Assembly Replacement
你所需要的
  1. Samsung Captivate Camera Assembly Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
    • Lift up the back cover.
  2. Samsung Captivate Camera Assembly Replacement: 步骤 2 中的图像 1,1
    • Place your finger on the bottom of the battery and lift to remove.
  3. Samsung Captivate Camera Assembly Replacement: 步骤 3 中的图像 1,1
    • Replace the old battery with the new one.
  4. Samsung Captivate Camera Assembly Replacement, Rear Case: 步骤 4 中的图像 1,1
    • Insert the spudger underneath the bottom section of the phone.
    • Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
  5. Samsung Captivate Camera Assembly Replacement: 步骤 5 中的图像 1,1
    • Remove the six 4.5mm #000 Phillips screws.
  6. Samsung Captivate Camera Assembly Replacement: 步骤 6 中的图像 1,3 Samsung Captivate Camera Assembly Replacement: 步骤 6 中的图像 2,3 Samsung Captivate Camera Assembly Replacement: 步骤 6 中的图像 3,3
    • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
    • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
    • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
  7. Samsung Captivate Camera Assembly Replacement: 步骤 7 中的图像 1,1
    • Separate the rear case from the phone.
  8. Samsung Captivate Camera Assembly Replacement, Camera Assembly: 步骤 8 中的图像 1,1
    • Use the spudger tool to pry up the chip labeled "NEC." This releases the chip.
  9. Samsung Captivate Camera Assembly Replacement: 步骤 9 中的图像 1,1
    • Gently lift the camera assembly out of the plastic housing.
结论
3等其他人完成本指南。
Drew Bentz
于09/22/11注册
565 声望
创作了5篇指南
团队
Cal Poly, Team 20-25, Maness Fall 2011 Cal Poly, Team 20-25, Maness Fall 2011 的会员
CPSU-MANESS-F11S20G25
3 名成员
创作了9篇指南
2指南评论
Is this for the front facing camera
tracy mann - 回复
No, this is for the rear facing camera. The Samsung Captivate does not have a front facing camera.
Will Budney -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 23
总计 2,385
