跳转到主内容
Samsung Captivate 3.5mm Headphone Jack Replacement
你所需要的
  1. Samsung Captivate 3.5mm Headphone Jack Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
    • Lift up the back cover.
  2. Samsung Captivate 3.5mm Headphone Jack Replacement: 步骤 2 中的图像 1,1
    • Place your finger on the bottom of the battery and lift to remove.
  3. Samsung Captivate 3.5mm Headphone Jack Replacement: 步骤 3 中的图像 1,1
    • Replace the old battery with the new one.
  4. Samsung Captivate 3.5mm Headphone Jack Replacement, Rear Case: 步骤 4 中的图像 1,1
    • Insert the spudger underneath the bottom section of the phone.
    • Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
  5. Samsung Captivate 3.5mm Headphone Jack Replacement: 步骤 5 中的图像 1,1
    • Remove the six 4.5mm #000 Phillips screws.
  6. Samsung Captivate 3.5mm Headphone Jack Replacement: 步骤 6 中的图像 1,3 Samsung Captivate 3.5mm Headphone Jack Replacement: 步骤 6 中的图像 2,3 Samsung Captivate 3.5mm Headphone Jack Replacement: 步骤 6 中的图像 3,3
    • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
    • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
    • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
  7. Samsung Captivate 3.5mm Headphone Jack Replacement: 步骤 7 中的图像 1,1
    • Separate the rear case from the phone.
  8. Samsung Captivate 3.5mm Headphone Jack Replacement, Antenna Cable: 步骤 8 中的图像 1,2 Samsung Captivate 3.5mm Headphone Jack Replacement, Antenna Cable: 步骤 8 中的图像 2,2
    • Use a spudger tool to pry up the antenna cable from the connector on the motherboard.
    • Pry up the other end of the cable from the connector on the antenna array.
  9. Samsung Captivate 3.5mm Headphone Jack Replacement, Motherboard: 步骤 9 中的图像 1,3 Samsung Captivate 3.5mm Headphone Jack Replacement, Motherboard: 步骤 9 中的图像 2,3 Samsung Captivate 3.5mm Headphone Jack Replacement, Motherboard: 步骤 9 中的图像 3,3
    • Using the spudger slide the tool under the three highlighted connectors to begin disconnection
    • Excluding the motherboard socket, pry straight from up under the connectors, Therefore ending disconnection.
    • Be careful to not pry against the connector. Prying against could further damage to the device.
  10. Samsung Captivate 3.5mm Headphone Jack Replacement: 步骤 10 中的图像 1,1
    • Use your fingers to carefully lift up the Samsung Capivate's Motherboard from the assembly.
  11. Samsung Captivate 3.5mm Headphone Jack Replacement, 3.5mm Headphone Jack: 步骤 11 中的图像 1,2 Samsung Captivate 3.5mm Headphone Jack Replacement, 3.5mm Headphone Jack: 步骤 11 中的图像 2,2
    • Gently pull up on the audio jack, taking the attached ribbon cable with it.
    • There is a small amount of glue holding the ribbon cable that attaches the audio jack to the earpiece.
结论
7等其他人完成本指南。
Christopher
于10/06/11注册
643 声望
创作了4篇指南
团队
Cal Poly, Team 20-25, Maness Fall 2011 Cal Poly, Team 20-25, Maness Fall 2011 的会员
CPSU-MANESS-F11S20G25
3 名成员
创作了9篇指南
一条评论
Between steps 7 and 8, there are a number of steps missing, including the removal of the camera, and the removal of the speaker assembly.
These can be found on the "Mother Board" repair manual, back on the device page.
~Desmond
Mobile Rapid Response Unit - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 7,711
