跳转到主内容
Samsung Camera LCD Replacement
  1. Samsung Camera LCD Replacement, Pin your LCD: 步骤 1 中的图像 1,1
    • How to replace the LCD ribbon cable on a Samsung SMX 30F. This ribbon connects the LCD to the motherboard of the camera. For a change of LCD only the process is much simpler and only takes about ten minutes.
  2. Samsung Camera LCD Replacement: 步骤 2 中的图像 1,3 Samsung Camera LCD Replacement: 步骤 2 中的图像 2,3 Samsung Camera LCD Replacement: 步骤 2 中的图像 3,3
    • Step 1: Remove the front block.
    • Remove all the screws on the front of the camera
  3. Samsung Camera LCD Replacement: 步骤 3 中的图像 1,1
    • Then gently pull on the block, be careful it is connected to the camera by rather short cables.
  4. Samsung Camera LCD Replacement: 步骤 4 中的图像 1,3 Samsung Camera LCD Replacement: 步骤 4 中的图像 2,3 Samsung Camera LCD Replacement: 步骤 4 中的图像 3,3
    • Remove all screws by walking around the unit. Be careful some are hidden under the handle, behind the hatches ....
  5. Samsung Camera LCD Replacement: 步骤 5 中的图像 1,3 Samsung Camera LCD Replacement: 步骤 5 中的图像 2,3 Samsung Camera LCD Replacement: 步骤 5 中的图像 3,3
    • To finish, remove the two screws connecting the screen to the body of the camera.
    • Now you can remove the shell of the camera, it must come easily if you feel resistance is that you left a screw somewhere.
  6. Samsung Camera LCD Replacement: 步骤 6 中的图像 1,3 Samsung Camera LCD Replacement: 步骤 6 中的图像 2,3 Samsung Camera LCD Replacement: 步骤 6 中的图像 3,3
    • Remove the case carefully, the cable disconnects easily from the very fragile connector.
    • You can now remove the screws securing the motherboard to the frame.
    • Then carefully remove the motherboard to gain access to the LCD cable.
  7. Samsung Camera LCD Replacement: 步骤 7 中的图像 1,3 Samsung Camera LCD Replacement: 步骤 7 中的图像 2,3 Samsung Camera LCD Replacement: 步骤 7 中的图像 3,3
    • Remove the cable from the frame.
    • Unscrew the 4 screen screws. and open it delicately using a pick.
    • Now, you can change the cable . The cable wraps around the metal axis, so make sure you count the number of rounds on disassembly to facilitate reassembly.
  8. Samsung Camera LCD Replacement: 步骤 8 中的图像 1,1
    • When reassembling, first position the metal clip and the small magnet in the black housing, before putting it back on the metal shaft.
结论
TO REASSEMBLE YOUR DEVICE FOLOW THESE INSTRUCTIONS IN REVERSE ORDER.
2等其他人完成本指南。
由衷感谢以下译者:
fr en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Hardy
于12/08/15注册
151 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 48
总计 799
