跳转到主内容
Samsung Blast Motherboard Replacement
你所需要的
  1. Samsung Blast Motherboard  Replacement, Motherboard: 步骤 1 中的图像 1,2 Samsung Blast Motherboard  Replacement, Motherboard: 步骤 1 中的图像 2,2
    • Remove the battery cover by pushing it upwards.
  2. Samsung Blast Motherboard  Replacement: 步骤 2 中的图像 1,1
    • Take out the battery.
  3. Samsung Blast Motherboard  Replacement: 步骤 3 中的图像 1,1
    • With a Phillips #00 screwdriver, remove the six screws that secure the back of the case.
    • You will not be able to completely remove the top two screws. Simply loosen them enough that you can still remove the cover.
  4. Samsung Blast Motherboard  Replacement: 步骤 4 中的图像 1,1
    • Pull off the back cover of the phone.
  5. Samsung Blast Motherboard  Replacement: 步骤 5 中的图像 1,2 Samsung Blast Motherboard  Replacement: 步骤 5 中的图像 2,2
    • Remove the volume and camera buttons by pulling them out.
    • Put the buttons aside until it is time to reassemble the phone.
  6. Samsung Blast Motherboard  Replacement: 步骤 6 中的图像 1,1
    • Use the small plastic opening tool to gently remove the motherboard from the rest of the phone.
  7. Samsung Blast Motherboard  Replacement: 步骤 7 中的图像 1,2 Samsung Blast Motherboard  Replacement: 步骤 7 中的图像 2,2
    • Gently grab the motherboard with tweezers, then disconnect it from the two attached plates.
结论
另外一个人完成了本指南。
团队
Ohio State, Team 1-5, Buehl Spring 2014 Ohio State, Team 1-5, Buehl Spring 2014 的会员
OSU-BUEHL-S14S1G5
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 307
