跳转到主内容
Samsung Blast Keyboard Replacement
你所需要的
  1. Samsung Blast Keyboard Replacement, At a Glance: 步骤 1 中的图像 1,2 Samsung Blast Keyboard Replacement, At a Glance: 步骤 1 中的图像 2,2
    • Your phone should look like this before disassembly.
  2. Samsung Blast Keyboard Replacement, Battery Case Removal: 步骤 2 中的图像 1,2 Samsung Blast Keyboard Replacement, Battery Case Removal: 步骤 2 中的图像 2,2
    • Remove the battery cover by sliding the back panel up. This will expose the battery.
  3. Samsung Blast Keyboard Replacement, Remove Battery/Sim card: 步骤 3 中的图像 1,1
    • Lift up the top portion of the battery and pull it out.
    • Next, slide the sim card out of its socket and set it aside.
  4. Samsung Blast Keyboard Replacement, Back Case Removal: 步骤 4 中的图像 1,2 Samsung Blast Keyboard Replacement, Back Case Removal: 步骤 4 中的图像 2,2
    • Use a Phillips #00 Screwdriver to unscrew the six small screws that secure the back of the case.
    • The top two screws are connected to the back cover. They will not come off once unscrewed.
    • Remove the case by prying around the edges.
    • Note the positions of button pads for reassembly.
  5. Samsung Blast Keyboard Replacement, Button Pads: 步骤 5 中的图像 1,2 Samsung Blast Keyboard Replacement, Button Pads: 步骤 5 中的图像 2,2
    • Remove the buttons for the camera and volume.
  6. Samsung Blast Keyboard Replacement, Motherboard Removal: 步骤 6 中的图像 1,3 Samsung Blast Keyboard Replacement, Motherboard Removal: 步骤 6 中的图像 2,3 Samsung Blast Keyboard Replacement, Motherboard Removal: 步骤 6 中的图像 3,3
    • Use a prying tool to detach the motherboard from main body.
    • Carefully detach the motherboard from the two connectors.
    • You could also use a pry tool for the second step.
    • Be careful with the motherboard as not to scrape or damage its components.
  7. Samsung Blast Keyboard Replacement, Keyboard Pad Replacement: 步骤 7 中的图像 1,2 Samsung Blast Keyboard Replacement, Keyboard Pad Replacement: 步骤 7 中的图像 2,2
    • Slide the keyboard straight up to free it from its alignment pins.
    • Swap the broken keyboard with a replacement here, and follow the repair steps in reverse order for reassembly.
结论
Jordan Taylor
于02/11/14注册
10 声望
撰写一个指南
团队
Ohio State, Team 1-5, Buehl Spring 2014 Ohio State, Team 1-5, Buehl Spring 2014 的会员
OSU-BUEHL-S14S1G5
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 260
