跳转到主内容
Samsung Blast Back Cover Replacement
你所需要的
  1. Samsung Blast Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Place the phone face down on the table. Locate a Phillips head screwdriver. Begin by first removing the four screws that surround the upper area of the Samsung phone.
  2. Samsung Blast Back Cover Replacement: 步骤 2 中的图像 1,1
    • Next, remove the side button by prying open the the side of the phone with a prying tool. Insert the prying tool between the back cover and the remainder of the phone. Slide the prying tool to the left, creating a division between the cover and the phone.
  3. Samsung Blast Back Cover Replacement: 步骤 3 中的图像 1,1
    • Continue using the prying tool to unlock the phone. If you hear a popping sound you know that you are on the right track. Be gentle as to not snap the screw-posts inside the case.
  4. Samsung Blast Back Cover Replacement: 步骤 4 中的图像 1,1
    • Finally, remove the back cover by gently lifting the case up, ensuring that nothing is still attached to the cover.
结论
另外一个人完成了本指南。
Joseph
于04/10/14注册
129 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 156
