跳转到主内容
Samsung Blackjack Motherboard Replacement
你所需要的
  1. Samsung Blackjack Motherboard Replacement, Back Phone Casing: 步骤 1 中的图像 1,2 Samsung Blackjack Motherboard Replacement, Back Phone Casing: 步骤 1 中的图像 2,2
    • Use the spudger to remove the rubber stoppers from the top of the cover.
    • Use the Phillips 00 screw driver to remove the screws from each of the four corners and the two on sides (six total).
  2. Samsung Blackjack Motherboard Replacement: 步骤 2 中的图像 1,3 Samsung Blackjack Motherboard Replacement: 步骤 2 中的图像 2,3 Samsung Blackjack Motherboard Replacement: 步骤 2 中的图像 3,3
    • Use the spudger to loosen and separate the front and back covers.
    • Pick up the back cover once loosened.
    • The front and back covers will be attached to each other by a gold wire.
    • Remove the gold wire connecting the back cover to the motherboard to completely separate the covers.
  3. Samsung Blackjack Motherboard Replacement, Volume/Scroll Wheel: 步骤 3 中的图像 1,2 Samsung Blackjack Motherboard Replacement, Volume/Scroll Wheel: 步骤 3 中的图像 2,2
    • Use the screwdriver to unscrew the four screws that hold the scroll wheel in place.
    • Use your fingers to remove the scroll wheel and the metal plate that it is attached to.
  4. Samsung Blackjack Motherboard Replacement: 步骤 4 中的图像 1,2 Samsung Blackjack Motherboard Replacement: 步骤 4 中的图像 2,2
    • Use the spudger to unsnap the gold wire connection that connects the back casing to the logic board.
    • Use the spudger to unsnap the gold wire connection that connects the scroll wheel assembly to the logic board.
  5. Samsung Blackjack Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,2 Samsung Blackjack Motherboard Replacement, Motherboard: 步骤 5 中的图像 2,2
    • Use the spudger to unsnap the black rectangular connection from the motherboard.
    • Use the Phillips 00 screwdriver to remove all of the screws that hold the motherboard in place.
  6. Samsung Blackjack Motherboard Replacement: 步骤 6 中的图像 1,2 Samsung Blackjack Motherboard Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use the tweezers to unsnap the connection between the motherboard and the speaker. The speaker is attached to the front casing.
  7. Samsung Blackjack Motherboard Replacement: 步骤 7 中的图像 1,2 Samsung Blackjack Motherboard Replacement: 步骤 7 中的图像 2,2
    • Once all of the connections have been snapped off of the motherboard, the motherboard can be removed.
    • Lift up on the motherboard and it will come free of the front casing.
结论
Kristin Manna
于10/22/12注册
29 声望
创作了10篇指南
团队
Clemson, Team 14-4, Benson Fall 2012 Clemson, Team 14-4, Benson Fall 2012 的会员
CLEM-BENSON-F12S14G4
3 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 14
总计 485
