跳转到主内容
Samsung Blackjack Keypad Replacement
你所需要的
  1. Samsung Blackjack Keypad Replacement, Battery Cover: 步骤 1 中的图像 1,3 Samsung Blackjack Keypad Replacement, Battery Cover: 步骤 1 中的图像 2,3 Samsung Blackjack Keypad Replacement, Battery Cover: 步骤 1 中的图像 3,3
    • Hold the device with the screen facing away from you and the camera towards you.
    • Place your thumb on the bottom half of the phone and slide the cover off while gently pushing down on the cover.
  2. Samsung Blackjack Keypad Replacement, Battery: 步骤 2 中的图像 1,2 Samsung Blackjack Keypad Replacement, Battery: 步骤 2 中的图像 2,2
    • Place your fingers on both sides of the bottom of the battery and lift upwards.
    • Pull the battery away from the phone.
  3. Samsung Blackjack Keypad Replacement, Back Phone Casing: 步骤 3 中的图像 1,2 Samsung Blackjack Keypad Replacement, Back Phone Casing: 步骤 3 中的图像 2,2
    • Use the spudger to remove the rubber stoppers from the top of the cover.
    • Use the Phillips 00 screw driver to remove the screws from each of the four corners and the two on sides (six total).
  4. Samsung Blackjack Keypad Replacement: 步骤 4 中的图像 1,3 Samsung Blackjack Keypad Replacement: 步骤 4 中的图像 2,3 Samsung Blackjack Keypad Replacement: 步骤 4 中的图像 3,3
    • Use the spudger to loosen and separate the front and back covers.
    • Pick up the back cover once loosened.
    • The front and back covers will be attached to each other by a gold wire.
    • Remove the gold wire connecting the back cover to the motherboard to completely separate the covers.
  5. Samsung Blackjack Keypad Replacement, Motherboard: 步骤 5 中的图像 1,2 Samsung Blackjack Keypad Replacement, Motherboard: 步骤 5 中的图像 2,2
    • Use the spudger to unsnap the black rectangular connection from the motherboard.
    • Use the Phillips 00 screwdriver to remove all of the screws that hold the motherboard in place.
  6. Samsung Blackjack Keypad Replacement: 步骤 6 中的图像 1,2 Samsung Blackjack Keypad Replacement: 步骤 6 中的图像 2,2
    • Use the tweezers to unsnap the connection between the motherboard and the speaker. The speaker is attached to the front casing.
  7. Samsung Blackjack Keypad Replacement: 步骤 7 中的图像 1,2 Samsung Blackjack Keypad Replacement: 步骤 7 中的图像 2,2
    • Once all of the connections have been snapped off of the motherboard, the motherboard can be removed.
    • Lift up on the motherboard and it will come free of the front casing.
  8. Samsung Blackjack Keypad Replacement, Keypad: 步骤 8 中的图像 1,1
    • Hold the front cover with the keypad facing you.
    • Push down on the keypad to remove it from the case. The keypad will come right out because there is nothing connecting it to the front casing.
结论
Kristin Manna
于10/22/12注册
29 声望
创作了10篇指南
团队
Clemson, Team 14-4, Benson Fall 2012 Clemson, Team 14-4, Benson Fall 2012 的会员
CLEM-BENSON-F12S14G4
3 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 370
