当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Hold the device with the screen facing away from you and the camera towards you.
Place your thumb on the bottom half of the phone and slide the cover off while gently pushing down on the cover.
Place your fingers on both sides of the bottom of the battery and lift upwards.
Pull the battery away from the phone.
Place your thumb on the SIM card.
Slide the card out of the slot.
Use the spudger to remove the rubber stoppers from the top of the cover.
Use the Phillips 00 screw driver to remove the screws from each of the four corners and the two on sides (six total).
Use the spudger to loosen and separate the front and back covers.
Pick up the back cover once loosened.
The front and back covers will be attached to each other by a gold wire.
Remove the gold wire connecting the back cover to the motherboard to completely separate the covers.
取消:我没有完成这个指南。
与5其他贡献者
于10/22/12注册
29 声望
创作了10篇指南
徽章: 7
+ 4更多徽章
CLEM-BENSON-F12S14G4
3 名成员
创作了14篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 13
总计 509
