跳转到主内容
Samsung Blackjack Antenna Replacement
你所需要的
  1. Samsung Blackjack Antenna Replacement, Battery Cover: 步骤 1 中的图像 1,3 Samsung Blackjack Antenna Replacement, Battery Cover: 步骤 1 中的图像 2,3 Samsung Blackjack Antenna Replacement, Battery Cover: 步骤 1 中的图像 3,3
    • Hold the device with the screen facing away from you and the camera towards you.
    • Place your thumb on the bottom half of the phone and slide the cover off while gently pushing down on the cover.
  2. Samsung Blackjack Antenna Replacement, Battery: 步骤 2 中的图像 1,2 Samsung Blackjack Antenna Replacement, Battery: 步骤 2 中的图像 2,2
    • Place your fingers on both sides of the bottom of the battery and lift upwards.
    • Pull the battery away from the phone.
  3. Samsung Blackjack Antenna Replacement, SIM Card: 步骤 3 中的图像 1,3 Samsung Blackjack Antenna Replacement, SIM Card: 步骤 3 中的图像 2,3 Samsung Blackjack Antenna Replacement, SIM Card: 步骤 3 中的图像 3,3
    • Place your thumb on the SIM card.
    • Slide the card out of the slot.
  4. Samsung Blackjack Antenna Replacement, Back Phone Casing: 步骤 4 中的图像 1,2 Samsung Blackjack Antenna Replacement, Back Phone Casing: 步骤 4 中的图像 2,2
    • Use the spudger to remove the rubber stoppers from the top of the cover.
    • Use the Phillips 00 screw driver to remove the screws from each of the four corners and the two on sides (six total).
  5. Samsung Blackjack Antenna Replacement: 步骤 5 中的图像 1,3 Samsung Blackjack Antenna Replacement: 步骤 5 中的图像 2,3 Samsung Blackjack Antenna Replacement: 步骤 5 中的图像 3,3
    • Use the spudger to loosen and separate the front and back covers.
    • Pick up the back cover once loosened.
    • The front and back covers will be attached to each other by a gold wire.
    • Remove the gold wire connecting the back cover to the motherboard to completely separate the covers.
  6. Samsung Blackjack Antenna Replacement, Antenna: 步骤 6 中的图像 1,2 Samsung Blackjack Antenna Replacement, Antenna: 步骤 6 中的图像 2,2
    • Note: The antenna is located on the back case of the phone. Flip over the back case of the phone so that the interior is facing up.
    • Use spudger to help loosen the antenna.
    • Once the antenna is loose, use tweezers to remove antenna.
  7. Samsung Blackjack Antenna Replacement: 步骤 7 中的图像 1,3 Samsung Blackjack Antenna Replacement: 步骤 7 中的图像 2,3 Samsung Blackjack Antenna Replacement: 步骤 7 中的图像 3,3
    • Use the Phillips 00 screwdriver to remove the screw from the casing around the speaker.
    • Use tweezers to lift the casing around the speaker.
    • Use spudger to dislodge the speaker.
结论
Kristin Manna
于10/22/12注册
29 声望
创作了10篇指南
团队
Clemson, Team 14-4, Benson Fall 2012 Clemson, Team 14-4, Benson Fall 2012 的会员
CLEM-BENSON-F12S14G4
3 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 406
