本指南有最近更改,您可查看未经巡查的最新版本。
简介
Use this guide to remove the front casing and to access the keypad.
你所需要的
Apply downward pressure to the top of the battery panel while pulling down to slide it off the phone.
Use the spudger to pry the two plastic caps out of the top corners of the phone casing.
Pry apart the plastic tabs along the edges of the phone.
Separate the front panel from the main body of the phone using your fingers.
另外一个人完成了本指南。
