跳转到主内容
Samsung BlackJack II Front Casing Replacement
你所需要的
  1. Samsung BlackJack II Front Casing Replacement, Battery: 步骤 1 中的图像 1,3 Samsung BlackJack II Front Casing Replacement, Battery: 步骤 1 中的图像 2,3 Samsung BlackJack II Front Casing Replacement, Battery: 步骤 1 中的图像 3,3
    • Apply downward pressure to the top of the battery panel while pulling down to slide it off the phone.
  2. Samsung BlackJack II Front Casing Replacement: 步骤 2 中的图像 1,3 Samsung BlackJack II Front Casing Replacement: 步骤 2 中的图像 2,3 Samsung BlackJack II Front Casing Replacement: 步骤 2 中的图像 3,3
    • Locate the grooves on the sides of the battery near the bottom of the phone. Use your fingers to pull the battery up and out of the phone.
  3. Samsung BlackJack II Front Casing Replacement, Back Casing: 步骤 3 中的图像 1,2 Samsung BlackJack II Front Casing Replacement, Back Casing: 步骤 3 中的图像 2,2
    • Use the spudger to pry the two plastic caps out of the top corners of the phone casing.
    • To get a better grip, you may use the tweezers to finish pulling the plastic caps from the phone.
  4. Samsung BlackJack II Front Casing Replacement: 步骤 4 中的图像 1,1
    • Remove the six 4.0 mm screws using the Phillips 00 screwdriver.
  5. Samsung BlackJack II Front Casing Replacement: 步骤 5 中的图像 1,3 Samsung BlackJack II Front Casing Replacement: 步骤 5 中的图像 2,3 Samsung BlackJack II Front Casing Replacement: 步骤 5 中的图像 3,3
    • Insert the plastic opening tool in the gap between the back panel and rest of the body.
    • Slide the tool along the edges until the two pieces come apart.
    • The circuit board is attached to the front casing. Both casings should separate without having to sever electrical connections.
  6. Samsung BlackJack II Front Casing Replacement, Front Casing: 步骤 6 中的图像 1,2 Samsung BlackJack II Front Casing Replacement, Front Casing: 步骤 6 中的图像 2,2
    • Pry apart the plastic tabs along the edges of the phone.
    • Separate the front panel from the main body of the phone using your fingers.
结论
另外一个人完成了本指南。
Ryan Rumsey
于01/30/13注册
8 声望
创作了6篇指南
团队
Cal Poly, Team 20-1, Maness Winter 2013 Cal Poly, Team 20-1, Maness Winter 2013 的会员
CPSU-MANESS-W13S20G1
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 429
