跳转到主内容
Samsung BN59-01199F Keypad Replacement
你所需要的
  1. Samsung BN59-01199F Keypad Replacement, Keypad: 步骤 1 中的图像 1,1
    • Remove the batteries before you disassemble the remote.
    • Use an opening pick in the seam of the controller and work it around the perimeter.
    • With the opening pick, scrape and remove the glue and undo the clips holding the top and bottom of the remote together.
  2. Samsung BN59-01199F Keypad Replacement: 步骤 2 中的图像 1,2 Samsung BN59-01199F Keypad Replacement: 步骤 2 中的图像 2,2
    • Use additional opening picks to keep the seam open.
    • Don't use a screwdriver or metal spudger for prying especially because the motherboard is directly underneath and could be damaged in the process.
    • Use a spudger or opening pick to work your way around the seam of the remote.
    • Separate the two sides of the remote.
  3. Samsung BN59-01199F Keypad Replacement: 步骤 3 中的图像 1,3 Samsung BN59-01199F Keypad Replacement: 步骤 3 中的图像 2,3 Samsung BN59-01199F Keypad Replacement: 步骤 3 中的图像 3,3
    • Remove the motherboard, the plastic button case, and finally the buttons from the plastic case.
    • Place the new keypad into the keypad holder and press to make sure it's set in securely.
  4. Samsung BN59-01199F Keypad Replacement: 步骤 4 中的图像 1,2 Samsung BN59-01199F Keypad Replacement: 步骤 4 中的图像 2,2
    • After replacing the rubber keypad, reassemble the remote.
    • Make sure to insert the light in the small hole during reassembly.
  5. Samsung BN59-01199F Keypad Replacement: 步骤 5 中的图像 1,3 Samsung BN59-01199F Keypad Replacement: 步骤 5 中的图像 2,3 Samsung BN59-01199F Keypad Replacement: 步骤 5 中的图像 3,3
    • When joining the two halves of the remote together line the spring up with the appropriate slot.
    • Carefully, press the two parts of the remote together.
  6. Samsung BN59-01199F Keypad Replacement: 步骤 6 中的图像 1,1
    • Make sure the remote is working after you put it back together and replaced the batteries.
结论
yeisom Garrido
于10/26/22注册
183 声望
撰写一个指南
团队
CSU Los Angeles, Team 1-46, Briggs Fall 2022 CSU Los Angeles, Team 1-46, Briggs Fall 2022 的会员
CSULA-BRIGGS-F22S1G46
1 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 57
总计 1,308
