简介
This guide will allow you to replace a faulty WiFi card. The WiFi card is the component on the Blu-Ray player that establishes and maintains internet connectivity. Connectivity issues such as slow streaming, degraded video quality, and dropped signals can all be fixed through a replacement of the WiFi card. Try troubleshooting your problem before using this guide.
Make sure the device is not plugged in before working on it.
工具
配件
没有特定配件。
Use the Phillips #00 Screwdriver to remove the single 9.6mm screw holding the top cover in place.
Remove the cover by sliding it up and then out.
Pull clip to remove the WiFi card ribbon connected to the circuit board.
Push the black plastic tab out and slide the WiFi card out from the cage.
另外一个人完成了本指南。
