跳转到主内容
Samsung BD-JM57C Power Cord Replacement
你所需要的
  1. Samsung BD-JM57C Power Cord Replacement, Top Cover: 步骤 1 中的图像 1,2 Samsung BD-JM57C Power Cord Replacement, Top Cover: 步骤 1 中的图像 2,2
    • Use the Phillips #00 Screwdriver to remove the single 9.6mm screw holding the top cover in place.
    • Remove the cover by sliding it up and then out.
  2. Samsung BD-JM57C Power Cord Replacement, Disc Drive: 步骤 2 中的图像 1,2 Samsung BD-JM57C Power Cord Replacement, Disc Drive: 步骤 2 中的图像 2,2
    • Disconnect the two ribbons that connect the disc drive to the motherboard.
  3. Samsung BD-JM57C Power Cord Replacement: 步骤 3 中的图像 1,2 Samsung BD-JM57C Power Cord Replacement: 步骤 3 中的图像 2,2
    • Push in on the two metal tabs on the side of the disc drive.
    • Push forward to slide the disc drive out of the casing.
  4. Samsung BD-JM57C Power Cord Replacement, WiFi Card: 步骤 4 中的图像 1,2 Samsung BD-JM57C Power Cord Replacement, WiFi Card: 步骤 4 中的图像 2,2
    • Pull clip to remove the WiFi card ribbon connected to the circuit board.
    • Push the black plastic tab out and slide the WiFi card out from the cage.
  5. Samsung BD-JM57C Power Cord Replacement, Power Cord: 步骤 5 中的图像 1,2 Samsung BD-JM57C Power Cord Replacement, Power Cord: 步骤 5 中的图像 2,2
    • Use the Phillips #00 Screwdriver to remove the two 6.4 mm screws holding the cage in place.
    • Lift the cage up to remove it.
  6. Samsung BD-JM57C Power Cord Replacement: 步骤 6 中的图像 1,1
    • Push in the small white lever and pull it towards you to release the cord.
  7. Samsung BD-JM57C Power Cord Replacement: 步骤 7 中的图像 1,1
    • Move the power cord out from under the metal tab on the side of the case.
  8. Samsung BD-JM57C Power Cord Replacement: 步骤 8 中的图像 1,1
    • Remove the rubber spacer on the edge of the case holding the cord in place.
    • Remove the power cord from the device.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 151
