跳转到主内容
Samsung BD-H5100 Motherboard Replacement
你所需要的
  1. Samsung BD-H5100 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Use the Phillips Head #2 screwdriver to remove the three 10mm screws on the back panel.
  2. Samsung BD-H5100 Motherboard Replacement: 步骤 2 中的图像 1,3 Samsung BD-H5100 Motherboard Replacement: 步骤 2 中的图像 2,3 Samsung BD-H5100 Motherboard Replacement: 步骤 2 中的图像 3,3
    • Use the plastic spudger to pry open the top panel.
    • Be careful not to break the ribbon connecting the motherboard on the bottom panel to the top panel.
  3. Samsung BD-H5100 Motherboard Replacement: 步骤 3 中的图像 1,2 Samsung BD-H5100 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Pull the ribbons gently from one corner by the blue tabs to remove it.
  4. Samsung BD-H5100 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Remove the two 7.5mm screws on both sides of the disk tray with Phillips Head #2 screwdriver.
  5. Samsung BD-H5100 Motherboard Replacement: 步骤 5 中的图像 1,2 Samsung BD-H5100 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Push two small prongs on both sides inwards and push forward.
    • Remove the disk tray.
  6. Samsung BD-H5100 Motherboard Replacement: 步骤 6 中的图像 1,2 Samsung BD-H5100 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Use a Phillips Head #2 to remove the two 7.5mm screws on the black cover.
    • Remove the black cover.
  7. Samsung BD-H5100 Motherboard Replacement: 步骤 7 中的图像 1,2 Samsung BD-H5100 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Pinch the white clip and pull straight up on the power cord.
    • Remove the power cord.
  8. Samsung BD-H5100 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Use a Phillips Head #2 to remove the 7.5mm screw.
  9. Samsung BD-H5100 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Use your finger to pry the metal tab slightly up.
    • This may break after several uses.
  10. Samsung BD-H5100 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Slide out the Motherboard.
    • Be careful when touching the bottom because it is sharp.
结论
Mira Patel
于10/11/16注册
580 声望
创作了5篇指南
团队
USF Tampa, Team 1-2, Leahy Fall 2016 USF Tampa, Team 1-2, Leahy Fall 2016 的会员
USFT-LEAHY-F16S1G2
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 11
总计 534
