跳转到主内容
Samsung BD-F7500 Blu-ray Player Power Cord Replacement
你所需要的
  1. Samsung BD-F7500 Blu-ray Player Power Cord Replacement, Power Cord: 步骤 1 中的图像 1,2 Samsung BD-F7500 Blu-ray Player Power Cord Replacement, Power Cord: 步骤 1 中的图像 2,2
    • Use a Phillips head #J1 screwdriver to remove all three (3) 10 mm screws.
  2. Samsung BD-F7500 Blu-ray Player Power Cord Replacement: 步骤 2 中的图像 1,2 Samsung BD-F7500 Blu-ray Player Power Cord Replacement: 步骤 2 中的图像 2,2
    • While firmly gripping the gray, metal base, lift the black plastic cover off the device.
    • The case is clamped onto the edges of the device, so bending of the plastic top will be required. Don't be afraid to use some force, it is unlikely that it will break.
    • Be careful not to tear ribbon cables attached to the outer cover.
  3. Samsung BD-F7500 Blu-ray Player Power Cord Replacement: 步骤 3 中的图像 1,3 Samsung BD-F7500 Blu-ray Player Power Cord Replacement: 步骤 3 中的图像 2,3 Samsung BD-F7500 Blu-ray Player Power Cord Replacement: 步骤 3 中的图像 3,3
    • Using the Philips head #J1 bit, remove the three (3) 10 mm screws that secure the plastic cover.
    • Gently remove the plastic cover.
  4. Samsung BD-F7500 Blu-ray Player Power Cord Replacement: 步骤 4 中的图像 1,2 Samsung BD-F7500 Blu-ray Player Power Cord Replacement: 步骤 4 中的图像 2,2
    • To remove the power cord, gently apply pressure to the tab located at the base of the cord and lift the cord with your fingers.
  5. Samsung BD-F7500 Blu-ray Player Power Cord Replacement: 步骤 5 中的图像 1,1
    • Locate the black plastic tab located on the power cord.
    • Using a spudger, gently insert the tool into the crack, to allow space for the wire to slide out.
    • Pull the plastic tab off of the wire, so that it can be placed on the replacement power cord.
结论
一条评论
Where can one find a replacement cord?
Jane Grey - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 8
总计 702
