跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Samsung BD-F5900 Power Supply Replacement
你所需要的
  1. Samsung BD-F5900 Power Supply Replacement, Top Cover: 步骤 1 中的图像 1,1
    • Using a #1 Phillips head screwdriver, remove the three 10mm screws on the back panel.
    • Tilt the back of the top cover forward to remove from chassis.
  2. Samsung BD-F5900 Power Supply Replacement: 步骤 2 中的图像 1,1
    • Gently pull up on the ribbon cable by the blue tab to remove it from the power supply board.
  3. Samsung BD-F5900 Power Supply Replacement, Power Supply: 步骤 3 中的图像 1,2 Samsung BD-F5900 Power Supply Replacement, Power Supply: 步骤 3 中的图像 2,2
    • Using a #1 Phillips head screwdriver, remove the two 7.5mm screws on top of the plastic cover and remove the cover.
  4. Samsung BD-F5900 Power Supply Replacement: 步骤 4 中的图像 1,1
    • Press down on the plastic retaining clip and pull backwards to remove the AC power connector from the power supply board.
  5. Samsung BD-F5900 Power Supply Replacement: 步骤 5 中的图像 1,3 Samsung BD-F5900 Power Supply Replacement: 步骤 5 中的图像 2,3 Samsung BD-F5900 Power Supply Replacement: 步骤 5 中的图像 3,3
    • Using the plastic spudger tool, gently pry on either side of main power connector (CON801) to disconnect from main logic board.
    • Pry a little bit on each side of board until the board lifts away.
    • Tilt the board forward and lift up to remove from the chassis.
结论
Louis McKean
于10/18/17注册
528 声望
创作了5篇指南
团队
USF Tampa, Team S1-G21, Cagle Fall 2017 USF Tampa, Team S1-G21, Cagle Fall 2017 的会员
USFT-CAGLE-F17S1G21
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 223
