简介
If you device will not turn on, it may be due to a defective power supply. If there are issues with the power supply on the device, this guide is here to demonstrate how to replace it.
你所需要的
Using a #1 Phillips head screwdriver, remove the three 10mm screws on the back panel.
Tilt the back of the top cover forward to remove from chassis.
Using a #1 Phillips head screwdriver, remove the two 7.5mm screws on top of the plastic cover and remove the cover.
即将完成!
结论
