跳转到主内容
Samsung BD-F5900 DVD Disc Tray Replacement
你所需要的
  1. Samsung BD-F5900 DVD Disc Tray Replacement, Top Cover: 步骤 1 中的图像 1,1
    • Using a #1 Phillips head screwdriver, remove the three 10mm screws on the back panel.
    • Tilt the back of the top cover forward to remove from chassis.
  2. Samsung BD-F5900 DVD Disc Tray Replacement: 步骤 2 中的图像 1,1
    • Gently pull up on the ribbon cable by the blue tab to remove it from the power supply board.
  3. Samsung BD-F5900 DVD Disc Tray Replacement, DVD Disc Tray: 步骤 3 中的图像 1,1
    • Remove the two ribbon cables from the Main Logic Board assembly by gently pulling up on the blue tab.
    • Be careful not to damage the ribbon cable by using too much force.
  4. Samsung BD-F5900 DVD Disc Tray Replacement: 步骤 4 中的图像 1,1
    • Using a #1 Phillips head screwdriver, remove the two 7.5 mm screws (one not shown) near the front that secures the disc tray to the chassis.
  5. Samsung BD-F5900 DVD Disc Tray Replacement: 步骤 5 中的图像 1,1
    • Push two small prongs on either side of disc tray inwards and push disc tray forward.
  6. Samsung BD-F5900 DVD Disc Tray Replacement: 步骤 6 中的图像 1,1
    • Remove disc tray
结论
另外一个人完成了本指南。
Louis McKean
于10/18/17注册
528 声望
创作了5篇指南
团队
USF Tampa, Team S1-G21, Cagle Fall 2017 USF Tampa, Team S1-G21, Cagle Fall 2017 的会员
USFT-CAGLE-F17S1G21
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 663
