简介
In this guide, you will learn how to replace or remove the power cord to a Samsung BD-F5700 Blu-Ray player. You will see step-by-step how to open the device, which screws to remove, and how to ultimately remove the power cord from the device. This repair would be needed if your device is no longer getting power to it. Always make sure the device is unplugged before beginning to work on it, as there is a chance of shock from exposed wiring.
工具
配件
没有特定配件。
Use Phillips 0 Screwdriver to remove two (2) 10 mm rear screws.
Use a plastic prying tool to help separate the top plastic casing from the bottom metal casing.
另外一个人完成了本指南。
