跳转到主内容
Samsung BD-F5700 Disc Reader Replacement
你所需要的
  1. Samsung BD-F5700 Disc Reader Replacement, Power Cord: 步骤 1 中的图像 1,3 Samsung BD-F5700 Disc Reader Replacement, Power Cord: 步骤 1 中的图像 2,3 Samsung BD-F5700 Disc Reader Replacement, Power Cord: 步骤 1 中的图像 3,3
    • Use Phillips 0 Screwdriver to remove two (2), 10 mm rear screws.
    • Use the iFixit opening tool to help separate the top plastic casing from the bottom metal casing.
    • When opening the device, be careful to not damage the ribbon cable circled in image 3.
  2. Samsung BD-F5700 Disc Reader Replacement: 步骤 2 中的图像 1,3 Samsung BD-F5700 Disc Reader Replacement: 步骤 2 中的图像 2,3 Samsung BD-F5700 Disc Reader Replacement: 步骤 2 中的图像 3,3
    • Use Phillips 0 screwdriver to remove two (2), 10 mm screws from the plastic cover.
    • Remove plastic cover from board.
  3. Samsung BD-F5700 Disc Reader Replacement: 步骤 3 中的图像 1,2 Samsung BD-F5700 Disc Reader Replacement: 步骤 3 中的图像 2,2
    • Pull upward on back of the black and white wire to dislocate the black tab piece from device.
    • To remove the cord from the device entirely, press on the white tab in the device and gently pull.
  4. Samsung BD-F5700 Disc Reader Replacement: 步骤 4 中的图像 1,1
    • Insert the iFixit Opening tool into the black tab on the power cord, and use leverage to open the black tab.
    • Pull the tab off the wire so that it can be placed on the replacement cord.
  5. Samsung BD-F5700 Disc Reader Replacement, Disc Reader: 步骤 5 中的图像 1,3 Samsung BD-F5700 Disc Reader Replacement, Disc Reader: 步骤 5 中的图像 2,3 Samsung BD-F5700 Disc Reader Replacement, Disc Reader: 步骤 5 中的图像 3,3
    • Firmly grip the hard plastic tab attached to the base and pull upwards.
    • It is important to not tear the ribbon cables.
  6. Samsung BD-F5700 Disc Reader Replacement: 步骤 6 中的图像 1,2 Samsung BD-F5700 Disc Reader Replacement: 步骤 6 中的图像 2,2
    • Remove the two 7mm screws with a Phillips #1 screwdriver.
  7. Samsung BD-F5700 Disc Reader Replacement: 步骤 7 中的图像 1,3 Samsung BD-F5700 Disc Reader Replacement: 步骤 7 中的图像 2,3 Samsung BD-F5700 Disc Reader Replacement: 步骤 7 中的图像 3,3
    • Pinch both tabs on the side of the disc tray, push towards the front, and lift the disc tray out to remove.
  8. Samsung BD-F5700 Disc Reader Replacement: 步骤 8 中的图像 1,3 Samsung BD-F5700 Disc Reader Replacement: 步骤 8 中的图像 2,3 Samsung BD-F5700 Disc Reader Replacement: 步骤 8 中的图像 3,3
    • Flip up the black locking tab on the ZIF connector.
  9. Samsung BD-F5700 Disc Reader Replacement: 步骤 9 中的图像 1,3 Samsung BD-F5700 Disc Reader Replacement: 步骤 9 中的图像 2,3 Samsung BD-F5700 Disc Reader Replacement: 步骤 9 中的图像 3,3
    • Remove the 10 mm screw using a Phillips #1 screwdriver.
    • Remove the small metal bar by pulling it outwards.
  10. Samsung BD-F5700 Disc Reader Replacement: 步骤 10 中的图像 1,2 Samsung BD-F5700 Disc Reader Replacement: 步骤 10 中的图像 2,2
    • Flip the disc tray over so the laser points downward.
    • Pull the disc reader out of the disc tray.
结论
2等其他人完成本指南。
Livan Perez
于02/15/18注册
303 声望
创作了2篇指南
团队
USF Tampa, Team S16-G4, Boczar Spring 2018 USF Tampa, Team S16-G4, Boczar Spring 2018 的会员
USFT-BOCZAR-S18S16G4
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 622
