跳转到主内容
Samsung BD-F5700 DC Power Board Replacement
你所需要的
  1. Samsung BD-F5700 DC Power Board Replacement, DC Power Board: 步骤 1 中的图像 1,1
    • Remove the three 10mm screws with a Phillips #0 screwdriver.
    • Pry the top off with a plastic opening tool.
  2. Samsung BD-F5700 DC Power Board Replacement: 步骤 2 中的图像 1,1
    • Remove the three screws holding down the cover with a Phillips #0 screwdriver.
  3. Samsung BD-F5700 DC Power Board Replacement: 步骤 3 中的图像 1,1
    • Lift up the power cord at its base to remove it.
  4. Samsung BD-F5700 DC Power Board Replacement: 步骤 4 中的图像 1,1
    • Insert a plastic opening tool into the black plastic tab on the cord and twist to separate.
  5. Samsung BD-F5700 DC Power Board Replacement: 步骤 5 中的图像 1,1
    • Remove the 7mm screw with a Phillips #1 screwdriver.
    • Grip the blue tab attached to the base and pull upwards.
  6. Samsung BD-F5700 DC Power Board Replacement: 步骤 6 中的图像 1,1
    • Grip the edges of the motherboard and pull upwards to remove.
结论
samer odeh
于02/13/18注册
313 声望
撰写一个指南
团队
USF Tampa, Team S16-G4, Boczar Spring 2018 USF Tampa, Team S16-G4, Boczar Spring 2018 的会员
USFT-BOCZAR-S18S16G4
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 16
总计 385
