跳转到主内容
Samsung BD-E5400 Wi-Fi Card Replacement
你所需要的
  1. Samsung BD-E5400 Wi-Fi Card Replacement, Outer Cover: 步骤 1 中的图像 1,2 Samsung BD-E5400 Wi-Fi Card Replacement, Outer Cover: 步骤 1 中的图像 2,2
    • Remove the two 10mm Phillips #1 screws.
    • Remove the one 8 mm Phillips #1 screw.
    • Carefully lift up the cover and lay back, to ensure that you do not damage the attached cable.
  2. Samsung BD-E5400 Wi-Fi Card Replacement: 步骤 2 中的图像 1,1
    • Unplug the small wiring bundle attaching the body of the device to the cover.
    • Lay the cover aside.
  3. Samsung BD-E5400 Wi-Fi Card Replacement, WIFI Card: 步骤 3 中的图像 1,3 Samsung BD-E5400 Wi-Fi Card Replacement, WIFI Card: 步骤 3 中的图像 2,3 Samsung BD-E5400 Wi-Fi Card Replacement, WIFI Card: 步骤 3 中的图像 3,3
    • The Wi-Fi card is the light blue component circled in red.
    • Separate the body of the Wi-Fi card from the black plastic cover.
    • Unplug the wires of the Wi-Fi card from the motherboard.
结论
Cameron Herring
于08/28/18注册
306 声望
创作了3篇指南
团队
IUPUI, Team S1-G3, Arle Fall 2018 IUPUI, Team S1-G3, Arle Fall 2018 的会员
IUPUI-ARLE-F18S1G3
3 名成员
创作了4篇指南
一条评论
I replaced my wifi card now none of the apps are working. I tried factory reset, and updating firmware nothing. Any ideas to get past this?
mike monroe - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 6
总计 277
