跳转到主内容
Samsung BD-E5400 Power Cord Replacement
你所需要的
  1. Samsung BD-E5400 Power Cord Replacement, Outer Cover: 步骤 1 中的图像 1,2 Samsung BD-E5400 Power Cord Replacement, Outer Cover: 步骤 1 中的图像 2,2
    • Remove the two 10mm Phillips #1 screws.
    • Remove the one 8 mm Phillips #1 screw.
    • Carefully lift up the cover and lay back, to ensure that you do not damage the attached cable.
  2. Samsung BD-E5400 Power Cord Replacement: 步骤 2 中的图像 1,1
    • Unplug the small wiring bundle attaching the body of the device to the cover.
    • Lay the cover aside.
  3. Samsung BD-E5400 Power Cord Replacement, Power Cord: 步骤 3 中的图像 1,2 Samsung BD-E5400 Power Cord Replacement, Power Cord: 步骤 3 中的图像 2,2
    • Remove the two 8 mm long, #1 Phillips head screws.
    • Lift up the plastic component cover to remove and lay aside.
  4. Samsung BD-E5400 Power Cord Replacement: 步骤 4 中的图像 1,3 Samsung BD-E5400 Power Cord Replacement: 步骤 4 中的图像 2,3 Samsung BD-E5400 Power Cord Replacement: 步骤 4 中的图像 3,3
    • With the motherboard exposed, locate the point where the power cord is attached.
    • Separate the portion of the cord encased in the black grommet from the frame of the device.
    • Unplug the power cord from the motherboard.
结论
Cameron Herring
于08/28/18注册
306 声望
创作了3篇指南
团队
IUPUI, Team S1-G3, Arle Fall 2018 IUPUI, Team S1-G3, Arle Fall 2018 的会员
IUPUI-ARLE-F18S1G3
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 5
总计 332
