跳转到主内容
Samsung BD-D5500 Disc Tray Replacement
你所需要的
  1. Samsung BD-D5500 Disc Tray Replacement, Samsung BD-D5500 Disassembly: 步骤 1 中的图像 1,1
    • To begin, turn the device over so that the bottom is facing up. There are 9 black clips that attach the plastic body to the case. Remove these clips from the case.
  2. Samsung BD-D5500 Disc Tray Replacement: 步骤 2 中的图像 1,2 Samsung BD-D5500 Disc Tray Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #2 screwdriver to remove the screw that attaches the top cover to the rear of the device. This will allow you to remove the cover.
    • This is how your device will look after you remove the top.
  3. Samsung BD-D5500 Disc Tray Replacement, Disc Tray: 步骤 3 中的图像 1,1
    • To remove the disc hub all you have to do is remove the 4 screws holding it down.
  4. Samsung BD-D5500 Disc Tray Replacement: 步骤 4 中的图像 1,1
    • To replace the disc tray open the disk hub and unsnap the sides of the device.
  5. Samsung BD-D5500 Disc Tray Replacement: 步骤 5 中的图像 1,1
    • Locate the slider that reads open and close.
    • To open the disc tray slide it to the side that says open.
  6. Samsung BD-D5500 Disc Tray Replacement: 步骤 6 中的图像 1,1
    • Return it face up and the disc tray will slide out.
结论
Brandon Nelson
于01/29/18注册
109 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 16
总计 1,012
