当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Push down on the back cover of the phone, then remove the back cover.
Remove the battery.
Remove the two (4.1 mm) screws down the screen.
Remove the upper casing with a plastic opening tools.
Use soldering iron to melt, and remove soldering joints of the speaker.
Use tweezers to remove the speaker from its place.
Note: There are two speakers. Make sure you know which one is broken before removing it.
Use tweezers to insert the new speaker into the speaker slot.
Solder a speaker ribbon to the logic board.
Note: be careful to match the right polarity before you solder.
取消:我没有完成这个指南。
与5其他贡献者
于04/16/11注册
133 声望
创作了5篇指南
徽章: 7
+ 4更多徽章
CPSU-MANESS-S11S12G35
4 名成员
创作了10篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 10
总计 2,103
