当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Push down on the back cover of the phone, then remove the back cover.
Remove the battery.
Remove the (4) 4.2 mm screws from the four corners of the battery slot.
Use plastic opening tools to peel off plastic Verizon logo tab from the top of the back outside.
Note: The tab is stuck on there with glue, this is alright, just peel it off.
Remove the (3) newly uncovered 4.3 mm screws.
Remove the back outside casing using the plastic opening tool.
Warning: Do Not lose the buttons on the side of the phone, as they will come off of the phone when you remove the back outside casing.
Pull up on the yellow tab.
Disconnect connecting cord using tweezers.
Disconnect rectangular ribbon.
Remove logic board.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与4其他贡献者
于04/16/11注册
133 声望
创作了5篇指南
徽章: 7
+ 4更多徽章
CPSU-MANESS-S11S12G35
4 名成员
创作了10篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,730
