跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
This guide tells you how to remove a faulty logic board and install a new one.
  1. push down the back cover of the phone, then take it out.
    • push down the back cover of the phone, then take it out.
  2. Remove the battery.
    • Remove the battery.
  3. Remove the (4) 4.2 mm screws from the four corners of the battery slot.
    • Remove the (4) 4.2 mm screws from the four corners of the battery slot.
  4. Use plastic opening tools to peel off plastic Verizon logo tab from the top of the back outside.
    • Use plastic opening tools to peel off plastic Verizon logo tab from the top of the back outside.
    • Note: The tab is stuck on there with glue, this is alright, just peel it off.
  5. 任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
    任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
  6. Remove the (3) newly uncovered 4.3 mm screws.
    • Remove the (3) newly uncovered 4.3 mm screws.
  7. Remove the back outside casing using the plastic opening tool.
    • Remove the back outside casing using the plastic opening tool.
    • Warning: Do Not lose the buttons on the side of the phone, as they will come off of the phone when you remove the back outside casing.
  8. Pull up on the yellow tab.
    • Pull up on the yellow tab.
  9. Disconnect connecting cord using tweezers.
    • Disconnect connecting cord using tweezers.
  10. Disconnect rectangular ribbon.
    • Disconnect rectangular ribbon.
  11. Remove logic board.
    • Remove logic board.
结论
另外一个人完成了本指南。
Chris
于2011年04月16日注册
133 信誉积分
创作了5篇指南
团队
Cal Poly, Team 12-35, Maness Spring 2011 Cal Poly, Team 12-35, Maness Spring 2011 的会员
CPSU-MANESS-S11S12G35
4 名成员
创作了10篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 4
总计 2,563
