当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Pull the two halves of the phone apart.
The phone will not slide straight apart. You have to angle the back half up a little.
Do not force it. Jiggle it a little if it doesn't come apart.
Remove the two 2.71 mm screws on the hinge using screwdriver.
Under these screws will be a washer, spring, and small metal disc. Make sure you don't lose these.
Remove the Verizon logo from the back of phone using the plastic opening tool.
The logo is attached with glue. It will be sticky, but it just pulls off.
Remove the four 4.44 mm screws from the back.
Remove the three 4.35mm screws from under the Verizon logo.
Make sure you don't mix the screws together.
Pull the back off by using the plastic opening tool.
Do not lose the buttons on the side of the phone, as they will come off of the phone when you remove the back outside casing.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
