当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Push down on the back cover of the phone, then remove the back cover.
Remove the battery.
Remove the (2) 4.1 mm screws on screen.
Remove front outside casing with plastic opening tools.
Use tweezers to remove the camera from its holding slot.
Use a plastic opening tool to lift the tab that holds the camera ribbon in place.
Use tweezers to remove the camera.
Slide ribbon of new camera under the same tab.
Close the tab down onto the new camera ribbon.
Use tweezers to put the new camera into the camera slot that previously held the old camera.
WARNING: Do not touch the camera lens as it will easily scratch or smudge.
取消:我没有完成这个指南。
与4其他贡献者
于04/16/11注册
133 声望
创作了5篇指南
徽章: 7
+ 4更多徽章
CPSU-MANESS-S11S12G35
4 名成员
创作了10篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 15
总计 2,297
