跳转到主内容
Samsung Admire Speaker Replacement
你所需要的
  1. Samsung Admire Speaker Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Use your fingernail or plastic opening tool to pull up the back cover of the phone from under the slit.
  2. Samsung Admire Speaker Replacement, Remove the battery: 步骤 2 中的图像 1,1
    • Carefully remove the battery by placing your fingernail underneath the hole and pulling out the battery.
    • Your hands should not be wet.
  3. Samsung Admire Speaker Replacement, Remove the screws: 步骤 3 中的图像 1,3 Samsung Admire Speaker Replacement, Remove the screws: 步骤 3 中的图像 2,3 Samsung Admire Speaker Replacement, Remove the screws: 步骤 3 中的图像 3,3
    • Use the Phillips #00 Precision Screwdriver to remove the six screws in the back of the phone.
  4. Samsung Admire Speaker Replacement, Inside back cover: 步骤 4 中的图像 1,3 Samsung Admire Speaker Replacement, Inside back cover: 步骤 4 中的图像 2,3 Samsung Admire Speaker Replacement, Inside back cover: 步骤 4 中的图像 3,3
    • Use the plastic opening tools to remove the inside back cover.
    • Place the plastic opening tools on the outside rim of the inside back cover.
    • Carefully lift the cover and circle around the rim to open the inside back cover completely.
    • Carefully disconnect ribbon cables and slowly lift the inside back cover to remove it.
  5. Samsung Admire Speaker Replacement, Speaker: 步骤 5 中的图像 1,2 Samsung Admire Speaker Replacement, Speaker: 步骤 5 中的图像 2,2
    • The speaker is located within the inside of the back cover.
    • Simply remove it by lifting it off with the plastic opening tool.
结论
2等其他人完成本指南。
Thao Uyen Do
于01/20/15注册
896 声望
创作了4篇指南
团队
USF Tampa, Team 7-5, Remmell Winter 2015 USF Tampa, Team 7-5, Remmell Winter 2015 的会员
USFT-REMMELL-W15S7G5
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 737
