跳转到主内容
Samsung Admire Screen Replacement
你所需要的
  1. Samsung Admire Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Slide your fingernail or plastic opening tool under the slit and pull the cover up.
  2. Samsung Admire Screen Replacement: 步骤 2 中的图像 1,1
    • Place your fingernail or plastic tool into the hole beneath the camera and carefully lift out the battery.
  3. Samsung Admire Screen Replacement: 步骤 3 中的图像 1,3 Samsung Admire Screen Replacement: 步骤 3 中的图像 2,3 Samsung Admire Screen Replacement: 步骤 3 中的图像 3,3
    • Use a Phillips #00 precision screwdriver to remove the six screws from the back of the phone.
  4. Samsung Admire Screen Replacement: 步骤 4 中的图像 1,3 Samsung Admire Screen Replacement: 步骤 4 中的图像 2,3 Samsung Admire Screen Replacement: 步骤 4 中的图像 3,3
    • Use the plastic opening tool to remove the inside back cover.
    • Use the plastic opening to pry the front and the back case apart.
    • As you lift the cover, move the plastic tool around the phone to pry up all of the screen.
    • Carefully disconnect the ribbon cables and slowly lift the inside back cover to remove it.
  5. Samsung Admire Screen Replacement: 步骤 5 中的图像 1,3 Samsung Admire Screen Replacement: 步骤 5 中的图像 2,3 Samsung Admire Screen Replacement: 步骤 5 中的图像 3,3
    • Lift the motherboard slowly.
    • Carefully disconnect the volume button from the motherboard.
    • Disconnect the two ribbon cables from the back of the motherboard.
  6. Samsung Admire Screen Replacement: 步骤 6 中的图像 1,3 Samsung Admire Screen Replacement: 步骤 6 中的图像 2,3 Samsung Admire Screen Replacement: 步骤 6 中的图像 3,3
    • Pull back on the five clips on the sides of the phone to remove the shield.
    • Be careful not to break the ribbon cables.
  7. Samsung Admire Screen Replacement: 步骤 7 中的图像 1,3 Samsung Admire Screen Replacement: 步骤 7 中的图像 2,3 Samsung Admire Screen Replacement: 步骤 7 中的图像 3,3
    • Use the plastic opening tool to unlatch the ribbon cable to disconnect it.
    • Place the plastic opening tool under the edge of the screen and lift the screen up carefully.
  8. Samsung Admire Screen Replacement: 步骤 8 中的图像 1,1
    • Insert new screen into the phone frame and reconnect the ribbon cable.
    • Follow steps in reverse order (omitting step eight) to reassemble the phone.
结论
12等其他人完成本指南。
Thao Uyen Do
于01/20/15注册
896 声望
创作了4篇指南
团队
USF Tampa, Team 7-5, Remmell Winter 2015 USF Tampa, Team 7-5, Remmell Winter 2015 的会员
USFT-REMMELL-W15S7G5
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 25
总计 1,649
