跳转到主内容
Samsung Admire Motherboard Replacement
你所需要的
  1. Samsung Admire Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,1
    • To open the back cover of the phone, use your fingernail or plastic opening tool under the slit to pull the cover up.
  2. Samsung Admire Motherboard Replacement, Remove Battery: 步骤 2 中的图像 1,1
    • Carefully remove the battery by placing your fingernail underneath the hole and pull out the battery.
    • Your hands should not be wet.
  3. Samsung Admire Motherboard Replacement, Remove the screws: 步骤 3 中的图像 1,3 Samsung Admire Motherboard Replacement, Remove the screws: 步骤 3 中的图像 2,3 Samsung Admire Motherboard Replacement, Remove the screws: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    购买
    • Use the Phillips #00 Precision Screwdriver to remove the six screws in the back of the phone.
    • Be careful not to lose the screws, so place them on a magnetic mat.
  4. Samsung Admire Motherboard Replacement, Inside back cover: 步骤 4 中的图像 1,3 Samsung Admire Motherboard Replacement, Inside back cover: 步骤 4 中的图像 2,3 Samsung Admire Motherboard Replacement, Inside back cover: 步骤 4 中的图像 3,3
    • Use the Plastic Opening tools to remove the inside back cover.
    • Place the Plastic Opening tools on the outside rim of the inside back cover.
    • Carefully lift the cover and circle around the rim to open the inside back cover completely.
    • Carefully disconnect ribbon cables and slowly lift the inside back cover to remove it.
  5. Samsung Admire Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,3 Samsung Admire Motherboard Replacement, Motherboard: 步骤 5 中的图像 2,3 Samsung Admire Motherboard Replacement, Motherboard: 步骤 5 中的图像 3,3
    • Lift the motherboard slowly.
    • Carefully disconnect the volume button away from the motherboard.
    • Disconnect the two ribbon cables from the back of the motherboard.
    • Remove the motherboard completely from the phone
结论
9等其他人完成本指南。
Thao Uyen Do
于01/20/15注册
896 声望
创作了4篇指南
团队
USF Tampa, Team 7-5, Remmell Winter 2015 USF Tampa, Team 7-5, Remmell Winter 2015 的会员
USFT-REMMELL-W15S7G5
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,305
