跳转到主内容
加入维修社区 - 创建账户
Samsung Ace Casing Replacement
你所需要的
  1. Samsung Ace Casing Replacement, Battery: 步骤 1 中的图像 1,3 Samsung Ace Casing Replacement, Battery: 步骤 1 中的图像 2,3 Samsung Ace Casing Replacement, Battery: 步骤 1 中的图像 3,3
    • To remove the back casing, firmly press down and push towards the bottom of the phone.
  2. Samsung Ace Casing Replacement: 步骤 2 中的图像 1,1
    • With the casing removed, lift the battery from the indicated indentation.
  3. Samsung Ace Casing Replacement: 步骤 3 中的图像 1,1
    • From here, you can now access the SIM card and model/serial numbers.
  4. Samsung Ace Casing Replacement, Casing: 步骤 4 中的图像 1,1
    • Using the Phillips #00 screwdriver, remove the four indicated screws (4.5 mm).
  5. Samsung Ace Casing Replacement: 步骤 5 中的图像 1,2 Samsung Ace Casing Replacement: 步骤 5 中的图像 2,2
    • Press the pointed edge of the spudger into the side of the two rubber plugs in order to lift and remove them from the top of the phone.
    • Then, using the Phillips #00 screwdriver, remove the two indicated Phillip screws (6.5 mm).
  6. Samsung Ace Casing Replacement: 步骤 6 中的图像 1,1
    • To remove the SIM card, start by pressing the top of the card and push down and away towards the bottom of the phone. Then, as indicated, pull the SIM card out.
  7. Samsung Ace Casing Replacement: 步骤 7 中的图像 1,2 Samsung Ace Casing Replacement: 步骤 7 中的图像 2,2
    • Begin to slowly lift the back casing of the phone. You should hear a snap when the casing is released.
    • The power, volume, and camera buttons may fall out when separating the front and back casing.
  8. Samsung Ace Casing Replacement: 步骤 8 中的图像 1,1
    • Your casing should be separated and the three loose buttons put to the side.
    • Be aware of the wiring on the top of the phone. Make sure not to pull it apart when separating the case.
  9. Samsung Ace Casing Replacement: 步骤 9 中的图像 1,2 Samsung Ace Casing Replacement: 步骤 9 中的图像 2,2
    • Slowly remove the back casing by gently pulling the ribbon connection.
  10. Samsung Ace Casing Replacement: 步骤 10 中的图像 1,2 Samsung Ace Casing Replacement: 步骤 10 中的图像 2,2
    • Gently pull on the wires to remove the front casing.
  11. Samsung Ace Casing Replacement: 步骤 11 中的图像 1,1
    • Your front casing and front speaker are now released.
结论
Breanne
于04/12/12注册
187 声望
创作了5篇指南
团队
Cal Poly, Team 6-24, Amido Spring 2012 Cal Poly, Team 6-24, Amido Spring 2012 的会员
CPSU-AMIDO-S12S6G24
3 名成员
创作了17篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 28
总计 955
