简介
Replace the right speaker once you've identified that it's not working. The right speaker should be labeled with an "R." Be sure to power off the device before starting anything else. You will need to remove the backplate and battery before replacing the right speaker.
你所需要的
Remove the stylus from the device.
Place the device screen-up on a hard surface, like a table.
Disconnect the three ribbon cables from the motherboard to free the battery.
Use your finger to lift the flap securing each ZIF connector.
Slide the ribbon cable out and towards you. Now it should be completely detached.
Repeat with the other two cables.
Locate the right speaker.
Locate the 3.5-mm screws and remove them with the Phillips #00 Screwdriver.
