跳转到主内容
Samsung ATIV Smart PC 500T Left Speaker Replacement
你所需要的
  1. Samsung ATIV Smart PC 500T Left Speaker Replacement, Backplate: 步骤 1 中的图像 1,2 Samsung ATIV Smart PC 500T Left Speaker Replacement, Backplate: 步骤 1 中的图像 2,2
    • Remove the stylus from the device.
    • Place the device screen-up on a hard surface, like a table.
  2. Samsung ATIV Smart PC 500T Left Speaker Replacement: 步骤 2 中的图像 1,3 Samsung ATIV Smart PC 500T Left Speaker Replacement: 步骤 2 中的图像 2,3 Samsung ATIV Smart PC 500T Left Speaker Replacement: 步骤 2 中的图像 3,3
    • Insert a plastic pry tool or opening pick between the glass and plastic case.
    • Work your way around the plastic edge, unclipping the backplate.
    • Once the clips are loosened, remove the backplate. Some force may be necessary.
    • Though you may need to use force, be careful of the pry tool slipping and hurting you!
  3. Samsung ATIV Smart PC 500T Left Speaker Replacement, Battery: 步骤 3 中的图像 1,3 Samsung ATIV Smart PC 500T Left Speaker Replacement, Battery: 步骤 3 中的图像 2,3 Samsung ATIV Smart PC 500T Left Speaker Replacement, Battery: 步骤 3 中的图像 3,3
    • Disconnect the three ribbon cables from the motherboard to free the battery.
    • Use your finger to lift the flap securing each ZIF connector.
    • Slide the ribbon cable out and towards you. Now it should be completely detached.
    • Repeat with the other two cables.
  4. Samsung ATIV Smart PC 500T Left Speaker Replacement: 步骤 4 中的图像 1,3 Samsung ATIV Smart PC 500T Left Speaker Replacement: 步骤 4 中的图像 2,3 Samsung ATIV Smart PC 500T Left Speaker Replacement: 步骤 4 中的图像 3,3
    • Get a firm hold of the power cable as close to the clip as you can.
    • Pull the power cable up and out of the clip.
  5. Samsung ATIV Smart PC 500T Left Speaker Replacement: 步骤 5 中的图像 1,3 Samsung ATIV Smart PC 500T Left Speaker Replacement: 步骤 5 中的图像 2,3 Samsung ATIV Smart PC 500T Left Speaker Replacement: 步骤 5 中的图像 3,3
    • Remove the six 3.5-mm screws using the Phillips #00 screwdriver.
    • Lift the battery out by hooking your finger under the tab on the top side of the battery and pulling it up and towards you. The battery should come out easily.
  6. Samsung ATIV Smart PC 500T Left Speaker Replacement, Left Speaker: 步骤 6 中的图像 1,2 Samsung ATIV Smart PC 500T Left Speaker Replacement, Left Speaker: 步骤 6 中的图像 2,2
    • Locate the left speaker.
    • The left speaker is labeled with an "L."
    • Locate the 3.5-mm screws and remove them with the Phillips #00 Screwdriver.
  7. Samsung ATIV Smart PC 500T Left Speaker Replacement: 步骤 7 中的图像 1,1
    • Once the screws have been removed, lift and remove the speaker from the device.
结论
Crystal Dinh
于09/23/15注册
1,026 声望
创作了4篇指南
团队
Baylor, Team 6-6, Williams Fall 2015 Baylor, Team 6-6, Williams Fall 2015 的会员
BU-WILLIAMS-F15S6G6
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 9
总计 988
