跳转到主内容
Samsung ATIV Book 9 Plus Speakers Replacement
你所需要的
  1. Samsung ATIV Book 9 Plus Speakers Replacement, Back Cover: 步骤 1 中的图像 1,3 Samsung ATIV Book 9 Plus Speakers Replacement, Back Cover: 步骤 1 中的图像 2,3 Samsung ATIV Book 9 Plus Speakers Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Speakers Replacement: 步骤 2 中的图像 1,1
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Speakers Replacement, Speakers: 步骤 3 中的图像 1,2 Samsung ATIV Book 9 Plus Speakers Replacement, Speakers: 步骤 3 中的图像 2,2
    • The speakers are black, and form a block-like "L" shape around the bottom half of the battery.
    • Lift from the corners of the speakers to remove them.
  4. Samsung ATIV Book 9 Plus Speakers Replacement: 步骤 4 中的图像 1,2 Samsung ATIV Book 9 Plus Speakers Replacement: 步骤 4 中的图像 2,2
    • After lifting the body of the speaker out of the laptop, you will notice that the top of the speaker is connected to the laptop by cables.
    • Continue removing the speakers by gently squeezing the sides of the white connector.
  5. Samsung ATIV Book 9 Plus Speakers Replacement: 步骤 5 中的图像 1,1
    • Gently tug on the white connector in order to remove the speakers.
结论
Karoline DaVee
于03/20/15注册
136 声望
撰写一个指南
团队
Baylor, Team 2-3, Grigsby Spring 2015 Baylor, Team 2-3, Grigsby Spring 2015 的会员
BU-GRIGSBY-S15S2G3
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 10
总计 1,489
