跳转到主内容
Samsung ATIV Book 9 Plus Keys Replacement
你所需要的
  1. Samsung ATIV Book 9 Plus Keys Replacement, Keys: 步骤 1 中的图像 1,2 Samsung ATIV Book 9 Plus Keys Replacement, Keys: 步骤 1 中的图像 2,2
    • Open your laptop so your keyboard is facing you and is easily accessible.
  2. Samsung ATIV Book 9 Plus Keys Replacement: 步骤 2 中的图像 1,3 Samsung ATIV Book 9 Plus Keys Replacement: 步骤 2 中的图像 2,3 Samsung ATIV Book 9 Plus Keys Replacement: 步骤 2 中的图像 3,3
    • Using a plastic opening tool, carefully push the thin tip under the key.
  3. Samsung ATIV Book 9 Plus Keys Replacement: 步骤 3 中的图像 1,2 Samsung ATIV Book 9 Plus Keys Replacement: 步骤 3 中的图像 2,2
    • Pivot the tool upwards. This should pry the key away from the keyboard.
    • Hearing some snapping sounds should be normal as the key lifts away from its attachments.
    • Continue lifting the tool until the key comes away completely or gently pull the key off. Repeat for other keys as needed.
    • Be gentle, as the attachments may accidentally break with rough handling.
结论
3等其他人完成本指南。
unknown
于03/20/15注册
261 声望
撰写一个指南
团队
Baylor, Team 2-3, Grigsby Spring 2015 Baylor, Team 2-3, Grigsby Spring 2015 的会员
BU-GRIGSBY-S15S2G3
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 6,132
