跳转到主内容
Samsung ATIV Book 9 Plus Internal Fans Replacement
你所需要的
  1. Samsung ATIV Book 9 Plus Internal Fans Replacement, Back Cover: 步骤 1 中的图像 1,3 Samsung ATIV Book 9 Plus Internal Fans Replacement, Back Cover: 步骤 1 中的图像 2,3 Samsung ATIV Book 9 Plus Internal Fans Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Internal Fans Replacement: 步骤 2 中的图像 1,1
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Internal Fans Replacement, Internal Fans: 步骤 3 中的图像 1,3 Samsung ATIV Book 9 Plus Internal Fans Replacement, Internal Fans: 步骤 3 中的图像 2,3 Samsung ATIV Book 9 Plus Internal Fans Replacement, Internal Fans: 步骤 3 中的图像 3,3
    • The fans should be in the upper left corner of the laptop if the laptop is oriented with the battery in the bottom half.
    • Gently lift the fans' black connector strip out of the way.
  4. Samsung ATIV Book 9 Plus Internal Fans Replacement: 步骤 4 中的图像 1,2 Samsung ATIV Book 9 Plus Internal Fans Replacement: 步骤 4 中的图像 2,2
    • Using a Phillips head screwdriver, unscrew four 4.55 mm Phillips #000 screws that bind the fans.
  5. Samsung ATIV Book 9 Plus Internal Fans Replacement: 步骤 5 中的图像 1,1
    • Disconnect the white connectors by gently tugging on them.
    • Lift the fans from their positions.
结论
2等其他人完成本指南。
Rhannie Surel
于03/20/15注册
137 声望
撰写一个指南
团队
Baylor, Team 2-3, Grigsby Spring 2015 Baylor, Team 2-3, Grigsby Spring 2015 的会员
BU-GRIGSBY-S15S2G3
4 名成员
创作了4篇指南
一条评论
I think that's to easy!
Ocean - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 4,423
