跳转到主内容
Samsung ATIV Book 9 Plus Heatsink Assembly Replacement
你所需要的
  1. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Back Cover: 步骤 1 中的图像 1,3 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Back Cover: 步骤 1 中的图像 2,3 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: 步骤 2 中的图像 1,1
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Internal Fans: 步骤 3 中的图像 1,3 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Internal Fans: 步骤 3 中的图像 2,3 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Internal Fans: 步骤 3 中的图像 3,3
    • The fans should be in the upper left corner of the laptop if the laptop is oriented with the battery in the bottom half.
    • Gently lift the fans' black connector strip out of the way.
  4. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: 步骤 4 中的图像 1,2 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: 步骤 4 中的图像 2,2
    • Using a Phillips head screwdriver, unscrew four 4.55 mm Phillips #000 screws that bind the fans.
  5. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: 步骤 5 中的图像 1,1
    • Disconnect the white connectors by gently tugging on them.
    • Lift the fans from their positions.
  6. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Heatsink Assembly: 步骤 6 中的图像 1,1
    • Using a Phillips head screwdriver #000 unscrew the motherboard from the rest of the components.
  7. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: 步骤 7 中的图像 1,1
    • Disconnect the two cables shown in the picture by gently pulling them off.
  8. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: 步骤 8 中的图像 1,1
    • Using a Phillips #000 screwdriver, unscrew the three labeled screws to detach the heatsink assembly.
结论
Ryan Smith
于04/01/19注册
193 声望
创作了2篇指南
团队
IUPUI, Team S7-G7, Wilson Spring 2019 IUPUI, Team S7-G7, Wilson Spring 2019 的会员
IUPUI-WILSON-S19S7G7
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 617
