跳转到主内容
Samsung ATIV Book 9 Plus Charger Port Replacement
你所需要的
  1. Samsung ATIV Book 9 Plus Charger Port Replacement, Back Cover: 步骤 1 中的图像 1,3 Samsung ATIV Book 9 Plus Charger Port Replacement, Back Cover: 步骤 1 中的图像 2,3 Samsung ATIV Book 9 Plus Charger Port Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Charger Port Replacement: 步骤 2 中的图像 1,1
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Charger Port Replacement, Charger Port: 步骤 3 中的图像 1,2 Samsung ATIV Book 9 Plus Charger Port Replacement, Charger Port: 步骤 3 中的图像 2,2
    • Unscrew the 4.3mm screws holding down the plastic cover using a #000 screwdriver. After the screws are out remove the cover.
    • Remove the 4.3 mm screw holding down the metal cover using a #000 screwdriver.
  4. Samsung ATIV Book 9 Plus Charger Port Replacement: 步骤 4 中的图像 1,1
    • Disconnect the charging port from the motherboard by gently tugging on the plastic part of the connection.
  5. Samsung ATIV Book 9 Plus Charger Port Replacement: 步骤 5 中的图像 1,1
    • Wedge a plastic opening tool or spudger in between the laptop casing and the port. Pry until you feel it release.
    • This will take some force because the port is glued to the casing.
  6. Samsung ATIV Book 9 Plus Charger Port Replacement: 步骤 6 中的图像 1,1
    • Remove the disconnected charger port.
结论
3等其他人完成本指南。
Casey Kauffman
于11/06/17注册
329 声望
创作了2篇指南
团队
IUPUI, Team S6-G6, Baechle Fall 2017 IUPUI, Team S6-G6, Baechle Fall 2017 的会员
IUPUI-BAECHLE-F17S6G6
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 13
总计 1,921
