跳转到主内容
Samsung ATIV Book 9 NP900X3K-S01US Fan Assembly Replacement
你所需要的
  1. Samsung ATIV Book 9 NP900X3K-S01US Fan Assembly Replacement, Fan Assembly: 步骤 1 中的图像 1,1
    • Using the Phillips #00 screwdriver, remove the 10 screws holding the back panel together.
    • Remove the back panel.
  2. Samsung ATIV Book 9 NP900X3K-S01US Fan Assembly Replacement: 步骤 2 中的图像 1,1
    • Using the Phillips #00 screwdriver, remove the 4 total screws (2 per each fan).
    • Disconnect the cable connections linking each fan to the motherboard with a spudger.
    • Remove each fan.
结论
To reassemble your device, follow these instructions in reverse order or follow steps 4 to reassemble your laptop.
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 378
