跳转到主内容
Samsung ATIV Book 9 Lite Hard Drive Replacement
你所需要的
  1. Samsung ATIV Book 9 Lite Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,2 Samsung ATIV Book 9 Lite Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 2,2
    • Put a protective lining such as a piece of cloth in between the screen and the keyboard when closed to protect your screen when performing this replacement.
    • Turn the laptop upside down to show the screws holding the back cover on.
    • Using a Phillips #0, remove the ten 4mm screws located around the edges and one central.
  2. Samsung ATIV Book 9 Lite Hard Drive Replacement: 步骤 2 中的图像 1,3 Samsung ATIV Book 9 Lite Hard Drive Replacement: 步骤 2 中的图像 2,3 Samsung ATIV Book 9 Lite Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Use two plastic opening tools to separate the back cover from the laptop.
    • This may take some force because the back cover is snapped into place before the screws are used to keep it in place.
  3. Samsung ATIV Book 9 Lite Hard Drive Replacement: 步骤 3 中的图像 1,3 Samsung ATIV Book 9 Lite Hard Drive Replacement: 步骤 3 中的图像 2,3 Samsung ATIV Book 9 Lite Hard Drive Replacement: 步骤 3 中的图像 3,3
    • Using your hands or a plastic opening tool, release the yellow motherboard connection strip on both ends by lifting the clamps.
    • Remove the strip to reveal the hard drive.
  4. Samsung ATIV Book 9 Lite Hard Drive Replacement: 步骤 4 中的图像 1,2 Samsung ATIV Book 9 Lite Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Using a Phillips #0, remove the two 3mm screws holding the hard drive in place.
    • Remove the hard drive by pulling it out with your hands.
结论
2等其他人完成本指南。
Phat Tran
于09/16/18注册
786 声望
创作了5篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 50
总计 4,573
