跳转到主内容
Samsung ATIV Book 9 Lite Battery Replacement
你所需要的
  1. Samsung ATIV Book 9 Lite Battery Replacement, Battery: 步骤 1 中的图像 1,2 Samsung ATIV Book 9 Lite Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Put a protective lining such as a piece of cloth in between the screen and the keyboard when closed to protect your screen when performing this replacement.
    • Turn the laptop upside down to show the screws holding the back cover on.
    • Using a Phillips #0, remove the ten 4mm screws located around the edges and one central.
  2. Samsung ATIV Book 9 Lite Battery Replacement: 步骤 2 中的图像 1,3 Samsung ATIV Book 9 Lite Battery Replacement: 步骤 2 中的图像 2,3 Samsung ATIV Book 9 Lite Battery Replacement: 步骤 2 中的图像 3,3
    • Use two plastic opening tools to separate the back cover from the laptop.
    • This may take some force because the back cover is snapped into place before the screws are used to keep it in place.
  3. Samsung ATIV Book 9 Lite Battery Replacement: 步骤 3 中的图像 1,3 Samsung ATIV Book 9 Lite Battery Replacement: 步骤 3 中的图像 2,3 Samsung ATIV Book 9 Lite Battery Replacement: 步骤 3 中的图像 3,3
    • Using a Phillips #0, remove the seven 5mm screws highlighted in the image.
    • Using your hands, disconnect the battery's main cord from the main motherboard.
  4. Samsung ATIV Book 9 Lite Battery Replacement: 步骤 4 中的图像 1,2 Samsung ATIV Book 9 Lite Battery Replacement: 步骤 4 中的图像 2,2
    • Using your hands remove the battery from the computer.
结论
3等其他人完成本指南。
Phat Tran
于09/16/18注册
786 声望
创作了5篇指南
团队
2条评论
please where can i get the battery 🔋
Bethel Ugwudike - 回复
Please where can i get the battery for Samsung 930x5j910s5j940x5j
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 20
总计 1,688
