跳转到主内容
Samsung ATIV Book 9 Lite Audio Port Replacement
你所需要的
  1. Samsung ATIV Book 9 Lite Audio Port Replacement, Audio Port/USB2/Display Port Board: 步骤 1 中的图像 1,2 Samsung ATIV Book 9 Lite Audio Port Replacement, Audio Port/USB2/Display Port Board: 步骤 1 中的图像 2,2
    • Put a protective lining such as a piece of cloth in between the screen and the keyboard when closed to protect your screen when performing this replacement.
    • Turn the laptop upside down to show the screws holding the back cover on.
    • Using a Phillips #0, remove the ten 4mm screws located around the edges and one central.
  2. Samsung ATIV Book 9 Lite Audio Port Replacement: 步骤 2 中的图像 1,3 Samsung ATIV Book 9 Lite Audio Port Replacement: 步骤 2 中的图像 2,3 Samsung ATIV Book 9 Lite Audio Port Replacement: 步骤 2 中的图像 3,3
    • Use two plastic opening tools to separate the back cover from the laptop.
    • This may take some force because the back cover is snapped into place before the screws are used to keep it in place.
  3. Samsung ATIV Book 9 Lite Audio Port Replacement: 步骤 3 中的图像 1,3 Samsung ATIV Book 9 Lite Audio Port Replacement: 步骤 3 中的图像 2,3 Samsung ATIV Book 9 Lite Audio Port Replacement: 步骤 3 中的图像 3,3
    • Using your hands move the black and white wires that are layered on top of the board to be out of the way of the removal.
    • Using a Phillips #0, remove three 3.5mm screws.
  4. Samsung ATIV Book 9 Lite Audio Port Replacement: 步骤 4 中的图像 1,2 Samsung ATIV Book 9 Lite Audio Port Replacement: 步骤 4 中的图像 2,2
    • Using your hands remove the cord that connects the speakers to the board you are removing.
    • Do not pull on the cord as that might damage it; remove it by pulling on the white wire head.
    • Using your hands, remove the board from the computer.
结论
Phat Tran
于09/16/18注册
786 声望
创作了5篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 12
总计 492
