简介
This guide will show you how to replace the board containing the USB ports and the SD card reader on your laptop.
你所需要的
Remove the ten 5 mm screws that hold the backplate using the Phillips #000 screwdriver.
Remove the six 5mm screws that hold the battery by using the Phillips #0 screwdriver.
Disconnect the ribbon connecting the motherboard with the USB ports .
Disconnect the speaker from the board
即将完成!
结论
