跳转到主内容
Samsung ATIV Book 4 Screen Replacement
你所需要的
  1. Samsung ATIV Book 4 Screen Replacement, Screen: 步骤 1 中的图像 1,2 Samsung ATIV Book 4 Screen Replacement, Screen: 步骤 1 中的图像 2,2
    • Be sure the computer is off, and open the computer so that the screen is showing.
    • Use the plastic opening tool and pry away the casing surrounding the screen. Remove the casing entirely.
  2. Samsung ATIV Book 4 Screen Replacement: 步骤 2 中的图像 1,1
    • Remove the four 3.5mm screws securing the screen.
    • Tilt the screen back before removing the screws, there is a possibility it could fall and damage your keyboard or the ribbon cable connected to it.
  3. Samsung ATIV Book 4 Screen Replacement: 步骤 3 中的图像 1,1
    • Place the screen gently on the keyboard.
  4. Samsung ATIV Book 4 Screen Replacement: 步骤 4 中的图像 1,1
    • Remove the ribbon cable from the screen.
    • Remove and replace the screen.
结论
Daniel
于03/19/15注册
342 声望
创作了3篇指南
团队
Michigan Tech, Team 1-7, Lauer Spring 2015 Michigan Tech, Team 1-7, Lauer Spring 2015 的会员
MTU-LAUER-S15S1G7
2 名成员
创作了5篇指南
一条评论
Where do you buy the replacement screen for the ATIV Book 4? Thanks!
RMS015 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 18
总计 3,351
