跳转到主内容
Samsung ATIV Book 4 Mouse Pad Replacement
你所需要的
  1. Samsung ATIV Book 4 Mouse Pad Replacement, Mouse Pad: 步骤 1 中的图像 1,3 Samsung ATIV Book 4 Mouse Pad Replacement, Mouse Pad: 步骤 1 中的图像 2,3 Samsung ATIV Book 4 Mouse Pad Replacement, Mouse Pad: 步骤 1 中的图像 3,3
    • Place the computer upside down.
    • Remove the two rubber pads, by prying up on them.
    • There may be adhesive holding them down.
    • Remove the seven 6.5mm screws on exterior of computer.
    • Remove panel by sliding it down and lifting it away from the computer.
  2. Samsung ATIV Book 4 Mouse Pad Replacement: 步骤 2 中的图像 1,1
    • Remove the four 4.4mm screws that are underneath the panel.
    • Remove the two 6.5mm screws that were underneath the rubber pads.
  3. Samsung ATIV Book 4 Mouse Pad Replacement: 步骤 3 中的图像 1,2 Samsung ATIV Book 4 Mouse Pad Replacement: 步骤 3 中的图像 2,2
    • Using plastic opening tool, pry plastic panel away from computer.
    • Start prying at one point and work your way around the entire computer until panel is free come computer.
    • Remove the panel from computer once all tabs are broke free.
  4. Samsung ATIV Book 4 Mouse Pad Replacement: 步骤 4 中的图像 1,2 Samsung ATIV Book 4 Mouse Pad Replacement: 步骤 4 中的图像 2,2
    • Pull this tab outwards, as shown, to release the wire harness.
    • With the tab now pulled out, pull lightly on the blue tape, to remove the harness.
    • Pull on the blue tape to remove wire harness.
    • This harness may require a little more force to remove, but will slide right out.
    • Remove the two 3.5mm screws and remove the defective hardware.
    • This step may be easier if the battery is taken out. Follow the battery replacement guide to do so.
结论
Daniel
于03/19/15注册
342 声望
创作了3篇指南
团队
Michigan Tech, Team 1-7, Lauer Spring 2015 Michigan Tech, Team 1-7, Lauer Spring 2015 的会员
MTU-LAUER-S15S1G7
2 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 10
总计 1,094
