跳转到主内容
Samsung A3 2016 Model - A310F Display / LCD Replacement
你所需要的
  1. Samsung A3 2016 Model - A310F Display / LCD Replacement, Display / LCD: 步骤 1 中的图像 1,1
    • Remove the SIM tray from the phone.
  2. Samsung A3 2016 Model - A310F Display / LCD Replacement, Removing the battery cover: 步骤 2 中的图像 1,1
    • Use a heat gun or iOpener to heat the back of the phone.
    • Insert a spudger or thin bladed tool between the batery cover and frame.
    • Slide all the way around to release the adhesive holding the cover.
    • The battery cover is also glass and can break if too much pressure is applied when removeing.
  3. Samsung A3 2016 Model - A310F Display / LCD Replacement: 步骤 3 中的图像 1,2 Samsung A3 2016 Model - A310F Display / LCD Replacement: 步骤 3 中的图像 2,2
    • Remove all 16 screws from the housing
  4. Samsung A3 2016 Model - A310F Display / LCD Replacement: 步骤 4 中的图像 1,1
    • Hold the edge of the housing and push on the battery to release the display and mainboard from the housing.
    • You may need to go around the edge of the glass with a pick to remove any remaining adhesive
  5. Samsung A3 2016 Model - A310F Display / LCD Replacement: 步骤 5 中的图像 1,1
    • Remove the Philips screw securing the mainboard.
    • Remove the cable attached to the mainboard
    • Disconnect the display and camera connectors from the mainboard
  6. Samsung A3 2016 Model - A310F Display / LCD Replacement: 步骤 6 中的图像 1,2 Samsung A3 2016 Model - A310F Display / LCD Replacement: 步骤 6 中的图像 2,2
    • Disconnect the daughter board from the mainboard
  7. Samsung A3 2016 Model - A310F Display / LCD Replacement: 步骤 7 中的图像 1,1
    • Using a heatgun, heat the front of the display.
    • Use a spudger or pick to work the display and LCD free from the plastic housing. NOTE: The LCD is also glued to the frame and will probably break as well.
    • When mounting the new display, the display cable slots through a gap in the plastic frame and attaches to the mainboard.
  8. Samsung A3 2016 Model - A310F Display / LCD Replacement: 步骤 8 中的图像 1,3 Samsung A3 2016 Model - A310F Display / LCD Replacement: 步骤 8 中的图像 2,3 Samsung A3 2016 Model - A310F Display / LCD Replacement: 步骤 8 中的图像 3,3
    • Reattach the daughter board connector to the mainboard.
    • When re-inserting the mainboard, use a plastic spudger to push the battery pins in so the mainboard sits properly in the frame and the pins make a good contact with the battery.
    • Re-connect the display connector, camera and cable to the mainboard.
    • Screw the mainboard to the frame
  9. Samsung A3 2016 Model - A310F Display / LCD Replacement: 步骤 9 中的图像 1,1
    • Turn the phone on and test the display before removing the adhesive on the back of the display.
    • If everything works, remove the adhesive and attach the display to the plastic frame.
    • Push the display into the metal housing so it fits snugly.
  10. Samsung A3 2016 Model - A310F Display / LCD Replacement: 步骤 10 中的图像 1,2 Samsung A3 2016 Model - A310F Display / LCD Replacement: 步骤 10 中的图像 2,2
    • Replace the 16 screws that were removed in step 3.
    • Replace the battery cover and you are done.
结论
5等其他人完成本指南。
Harvey
于02/15/16注册
5,423 声望
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 3,581
